motec L120 logger mounting orientation
Fundamentos del cableado EFI
1830 Vistas
HI brainstrust
im mounting a motec l120 data logger. I cant find any mounting orientation information in the technical doccuments. I know the dash loggers need to be in a certain orientation for the G meter to read correctly is this the same for the 120?
cheers in advance
Craig
Its just needs to be "square" to the chassis, you can re-assign the channel names and scaling to each of the 3 axis of the internal accelerometer.
I have several of these mounted in LMP3 cars, just behind the driver seat directly on the floor with 3M DualLock. I can usually keep the Lateral G's the same, and just swap Vertical and Longitudinal G Forces.
thanks david
