Motorcycle connectors
Fundamentos del cableado EFI
1590 Vistas
Hi HPA,
I'm building a harness for a honda MSX (GROM) a mini motorcycle and looking at all of those car connectors in the guide videos I'm painfully aware I may need smaller connectors that are all sealed. Is there a recommendation for connectors that will work well for a motorcycle where space and durability are the main focus? I'm not opposed to using professional-level parts in these cases if it will help with decreasing the size of the connector and durability as they will have direct exposure to the elements.
Cheers,
Carl
Hi Carl you will most likely not need to join many wires at all as your loom will be so short
i would just wire direct to the sensors etc i would be using something like this if needed Deutsch connectors
Regards Ross
Thanks, yes the loom is quite short compared to a car. I'm trying to take this in a modular direction for easy expandability, troubleshooting, and replacement since motorcycles tend to be pretty hard wearing on their parts. Thanks for pointing me to the Deutsch connectors!
Cheers, Carl
