Normal label printer plus clear tubing
Fundamentos del cableado EFI
2035 Vistas
I have a normal label printer (the make is BROTHER, Model: P-Touch 1080, if it matters). Can I just use it to print a label and then recover it with clear shrink tubing?
I have actually tested it on a small piece of wiring and seems to work OK with no smugdeing, just wondering if it is a good idea as spending £00s on a printer to build a single harness is a bit excessive in my opinion.
Thanks
Doesnt that printer take the common TSE/TZE cartriges? https://www.aliexpress.com/item/32977967506.html
