Passing k type thermocouples through a bulkhead connector
Fundamentos del cableado EFI
917 Vistas
I have an ECUmaster CAN to EGT mounted on top of my gearbox and am monitoring 4 x egts on the engine.
I have 2x 34 pin Delphi bulkheads connectors also mounted on the gearbox to quickly disconnect the engine loom from the rest of the body wiring, to aid engine/box removal. These connectors use sicma 1.5 pins
Im wanting to add an additional 4 thermocouples to monitor additional temps on the body side of the car.
Will it be OK passing these through the bulkhead connector? The values these will be ready will be pretty low 50 to 100deg C
