Sizing wires in efi
Fundamentos del cableado EFI
503 Vistas
So I’m planning on running a big wire from alternator which will also be connected to the starter motor (how it is from oem). I will then splice these two together and in the same splice seperate into 6 serperate wires for the relays. Do i need to separate the amps between each wire ?
secondly, I have been told not to worry about load of wires when splicing on wires such as 5v supply and sensor ground. Is this true?
Thirdly if I am supplying wires to my injectors that each have a load of 1A then that will be 4A in total. Then on the same circuit I’m also supplying 2a to a wbo heater. Would I still separate the load evenly when splicing it into one bigger load wire?
thanlyou
