SPA Design Sensor wiring into Link G4+ Xtreme
Fundamentos del cableado EFI
1911 Vistas
I have 3 SPA design gauges with double sensors that i would like to wire into my Link ECU. I have removed the gauges and will just be using the sensors and displaying them on my AIM MXS Strada dash.
The sensors have 3 wires, a black, red and green.
How do i wire these into the Link?
Also, any ideas where i can get the calibration data for them? I will be using Fuel Pressure, Oil Temp, Oil Pressure, Water Temp
One would assume Red: +, Black: GND, Green: Signal.
In terms of calibration data, if you cant find it online, you will have to hook them up and test them. Pan of water, thermometer, multi-meter and read the outputs etc.
I wonder if they use pretty common sensors and maybe just re-brand them? Can you post up some pictures of them? They might be recognisable and give us a starting point to go from?
I haven't got any of my own pics that i can find but this is what the pressure ones look like for oil pressure. They are all stainless steel. And the gauges with sensors are pretty pricey.
https://goo.gl/images/MnQG8q
Looks like they use Gems sensors
