Star Point grounding
Fundamentos del cableado EFI
1622 Vistas
Hey im just trying to clarify, when you talk about current flow you mention current flowing from the positive side of the battery through the resistor and back through ground to the battery. is this just using "conventional" current theory for illustrative purposes because to my understanding current in a circuit flows from the negative side of the battery in a loop back through the positive.
