Trying to source colour and trace txl in Australia
Fundamentos del cableado EFI
1108 Vistas
I have currently only found gtp wire in aus in the colours and size i am needing
Is the tycab gtp wire better than some other brands? 3mm (1.13mm) wire rated at 20amp and temperture range up to 105c?
And they also do 6mm in colours I am needing but cant find txl
This is for a street car I am relocating the fuse/relay box to a board under drivers kick panel
TIA
Seems my reply didn't take.
There are a number of suppliers in Aussie for TXL and, depending on gauge, at least 19 different main and trace combinations - https://www.google.com/search?client=firefox-b-d&q=TXL+wiring+suppliers+in+Australia
Which have you checked out to see if they have what you need?
