TXL or Tefzel for use with DR-25
Fundamentos del cableado EFI
1391 Vistas
The Ecumaster Black comes with a FLRY-B wire spec harness which has a slightly low temperature rating, +105C, to use with DR-25. There are quite a few stories on partial insulation melting causing shorts.
The question is if TXL has a sufficiently high temperature rating at +125C or if Tefzel rated at +150C is needed?
