TXL Wire
Fundamentos del cableado EFI
1641 Vistas
Why we use TXL wire in EFI system and what are its specifications?
Waiting for feedback.
Thank you
Hello Nada,
TXL insulation has a heat rating of 125°C and is what OEMs use on production vehicles. It is more economical than the alternative, M22759/32 (Tefzel), which is used in motorsport.
PVC insulation is commonly found in auto parts stores and is not suitable to EFI wiring due to the low temperature rating of 60-90°C and very poor chemical resistance. It is only adequate for wiring trailers and the like.
