VQ35DE connectors
Fundamentos del cableado EFI
1884 Vistas
Hallo!
I would like to repin all my vq connectors, however I have no idea where to start looking or what the terminals are called that is used for the oem connectors. The assumption is also that all the connnectors/plugs doesnt contain the same terminals.
Would the best be to depin the connectors and try source from pictutes?
Or does anyone know if a place like RS components would sell these terminals?
While you may find what you are looking for at RS Components, Mouser, Digikey; you may have better luck at an automotive connector oriented supplier like Ballenger Motorsports.
For example, Ballenger has this page for the VQ35 connectors:
https://www.bmotorsports.com/shop/static.php/post/vq35
Great stuff! Thank you! I see they sell the terminals and seals separately too! So this makes life so much easier. And shipping to South Africa isnt that bad either.
Now to depin the connectors and see which pins are all the same to just order a bunch. :D
So I depinned all the connectors I need to redo on the harness and they all are the same! Whoohoo.
Ordering a bunch of connectors from ballenger next week!
Good news!
