Water meth pump to ecu wiring
Fundamentos del cableado EFI
1774 Vistas
Hello. I have motec m150 ecu and ineed wire the water meth pump to ecu with fail safe any one can explain haw can do this .
Or ineed best way to wire the water meth with fail safe
my plan is wire the pump to relay like fuel pump and put in line fuel pressure sensor its will work ?
Hello Bo there is some great threads already about this by typing water meth fail safe into the search bar above
https://www.hpacademy.com/forum/general-tuning-discussion/show/watermeth-fail-safe#post15579
Regards Ross
