When to twist wires?
Fundamentos del cableado EFI
1663 Vistas
Hi,
when do you twist wires?
Injector?
IAT?
TPS (5v-sensor ground - signal) ?
Thanks.
I only twist the wires if the cables needs to be more flexible. There is no need to twist any of those low-frequency signals.
CAN I twist anything data.
