Wiring Fundamentals - Crimping
Fundamentos del cableado EFI
1358 Vistas
What is the biggest size for open barrel that Delphi tool with part number : 12085271 can crimp the open barrel ?
G'day. The 'B' Die is the largest, and you'll get 5000cma of copper in here. If you're needing to splice more copper than this together, it might be worth looking into staggering smaller splices to work with the materials you've got on hand.
