wiring multipoint 6cly
Fundamentos del cableado EFI
1606 Vistas
hi
I am about to start wiring up a Haltech elite 750 on a 1997 EL Ford Falcon. It runs a distributor ignition type setup. I want to run it in multipoint injection mode. How would I wire up the fuel injectors?
Thanks.
I may be wrong, but isn't it a multi-point EFI as standard?
If you could give some idea where the problems you're having are, some of the chaps should be able to help. In the meantime, as it's a relatively common engine and conversion, you should find some help on the Haltech forums and installation guide.
