WinOLS can’t find demo file
Dominio de WinOLS: Identificación y edición de mapas
Módulo relevante: Habilidades prácticas de WinOLS > Configuración de WinOLS
Discusión y preguntas relacionadas con el curso WinOLS Mastery: Identificación y edición de mapas
1545 Vistas
Thank you for doing this course! I’m having issues getting WinOLS to find the demo file. Is there a certain location that works best for WinOLS to find it? I’m pretty sure I can figure out how to search folders but it just doesn’t see it.
Thanks in advance
I later discovered you just grab the file and drop in the center of winols. it then opens and saves to your folder
In the Winols folder? Anywhere in particular as I tried that as well with no luck.
not the folder, just drop it directly into the open software
Thanks yeah I finally opened it up yesterday and figured that out.
