Aeromotive 10 gallon brushless fuel pump current draw (A)
Instalación y configuración de PDM
2951 Vistas
Does anyone know how much amps does this pumps draws?
Aeromotive doesn't have any datasheet specifying that.
https://aeromotiveinc.com/products/10-0-gpm-brushless-spur-gear-fuel-pump-with-true-variable-speed-control-in-line?srsltid=AfmBOopcrS0jniGnQoBg2bEx-HD5weC_-maRAxarT8ed9_hPvj0AfqjK
It only says the following in the user manual:
60A fuse and 6 AWG wire. Is that it? Or its oversized?
At that level, you should be talking with the engineering support folks at Aeromotive. It seems like it's a positive displacement pump, so it probably really can draw 60A transient when feeding a -12 line at 150 psi. What a beast!
