Battery Isolator
Instalación y configuración de PDM
2609 Vistas
4:29 in the Isolation module. There's an image of an MSEL isolator with Radlok connectors.
Is that a product that can be purchased? Or was that unit custom modified or custom built?
It does appear like the label on the unit is peeling off, possibly indicating that one has been disassembled/reassembled.
If you are looking for an isolator with Radlok connectors, I know they are available on the ECUMaster isolator and it also has a higher, 300A continuous current capability and IP67 rating... it does cost a bit more though.
Yeah, except I already have the MSEL, so if there's some way to mod it, that would be cool
Hi Matt,
Have you asked MSEL directly about this?
No, never even thought of it until I saw it in the lesson video here
