ECM PMU16 AND ALTERNATOR
Instalación y configuración de PDM
1803 Vistas
Hello, what is the right way to wire up the alternator D+ with use of ecumaster pmu16? I also use Ecm dash. Do i need a charge-bulbe? Can i have a charge light showing in the dash? I want to do it the easiest way. I also use Link G+s (Bmw e36 m3 turbo)
-Turbokarlsen
Did you figure this out?
