ECUMaster PMU + Keypad - How to setup multiple switch stages
Instalación y configuración de PDM
3107 Vistas
Hi,
I'm playing around the ECU Master PMU software while I watch the course videos.
I've understand that to setup the wipers module is very easy:
Just setup the Multiple Swipes input channel and define which stage (0 to 3) corresponds to each speed.
But If I want to have just one button on keypad to power on Position Lights, Low Beam and High Beam.
0 = off
1 = Position Lights
2 = Low Beam
3 = High Beam
I should set it up on the keypad menu, like this:
Or do I have to set up a formula for each channel just like this:
Hi Haruki,
I believe the force state channels available when configuring a keypad are intended to be used to override a keypad button's state when that condition is true.
If you wish to control your outputs based on a button with multiple states you will need to set the formula as you have done in your post.
