In the practical reflash tuning there are examples using LS1 engines and HPTuners software. How is AFR wideband data being accessed and being displayed on the scanner? I only know of the innovate device AFR Gauge/O2 sensor , is there any alternative as I have access to a Mainline Hub dyno which has AFR probe as well as OBD II interface so seems like a duplication to buy the innovate product.
If you want to see and log the data in the VCM Scanner, sometimes you can use the OEM O2 sensor if it's a wideband. If not, you will need to buy the Pro Link and the Pro feature set to use an external controller like the Innovate or AEM.
