Main power cable routing/posts.
Instalación y configuración de PDM
428 Vistas
In the working with large gauge cable module. Zac states he would run power from the battery to the bulkhead through panel stud, and use this as a distribution post.
I would just like to check if there is any harm in using the PMU as the distribution post? My plan was:
Battery >>Circuit breaker >> PMU
PMU >> Bulkhead (goes to starter, which also has the alternator feed connected to it) and also to a small always live and accessories switched fuse box.
This is mainly due to efficient routing as my PMU comes before the bulkhead mounted Radlok connector and will also be next to where the small fuse boxes will be. But is there any harm in having it wired this way given the high current that will flow on starting?
