PDM28 battery connection.
Instalación y configuración de PDM
1321 Vistas
Hi guys,
I picked up my Hardwire Electronics PDM28 this morning.
just a question regarding powering the unit.
I had always envisioned powering the unit, with everything in similar locations, as Zac mentions in the Large gauge cable module. However, an email from the supplier states direct connection to the battery and not sharing with other devices eg. starter motor.
I would assume that the 50mm cable does the job of "moving" the terminal to the bulkhead and there is no need to run a 35mm wire to the rear of the vehicle, can anyone see otherwise?
see an excerpt from the email and diagram of how I had planned my battery power system
