PMU total current output
Instalación y configuración de PDM
Módulo relevante: Ejemplos resueltos > Ejemplo práctico de ECUMaster PMU16 > Paso 1: Enumere los componentes del sistema y determine el consumo de energía
1363 Vistas
I noted that you propose to make use of 2 off PMU16's in order to have sufficient current capacity for your vehicle. You felt that having an estimated requirement for 148 Amps was too close to the PMU16's maximum of 150 Amps. If you chose to use the PMU16-AS version you get a maximum capacity of 200 Amps which would give you a good safety margin. Is this something you have considered?
That unit may not have been available at the time, but is certainly worth considering today!
