Wiring up a switch panel to a PMU16 and for what ever reason I can not remove the 5v from the input wires that go from the switch panel to the PMU16
So most devices with digital inputs have a pull-up resistor on the input, so you only need to ground the input to change the state. What does the wiring instructions for the PMU16 indicate with regard to how to wire switches?
