Hi Guys,
I've programmed my PMU and ran a number of events thankfully without any issues - however I want to continuously improve on my programming and I want to get the reset function working correctly if an error arises e.g. cooling fan tripping out! how do I program it to reset to firstly get the fan working and clear the fault on the PMU? I've tried a few things but to no avail when I induce a fault into the system.
Thanks,
Gar
Gar,
If you are allowing auto retries, that occasionally resolves something. More often there's an issue that won't quickly "fix itself".
It's good to have the manual force retry option available, which I usually assign to a CAN keypad button, but when you think about what would cause a fault, it's most often an issue that needs physically fixed via repair or replacement of parts, or the calibration perhaps had the threshold for a fault set too close to normal operation.
The manual retry of all faulted circuits is set as the Master retry channel, available via the Configuration tab.
Perhaps if you give us specifics on your test procedure we'll better understand what you're experiencing and how we can help you more.
