Using pmu input for wheel speed
Instalación y configuración de PDM
1696 Vistas
Is it possible to run my wheel speed sensors to the pmu then send it to the ecu via can?
Don't believe so no, the inputs on the PMU are analog not digital speed.
ECUmaster makes a wheel speed to CAN module, or the ADU has 8 digital inputs
