2006 Honda Accord 3.0 v6 6 speed
Introducción al ajuste del motor
2037 Vistas
Currently in the process of adding a turbo to my J30A5. I have all the intercooler piping done and the the exhaust is fabricated so that it is all bolt on when I'm finally ready to set the turbo in the engine bay permanently. I am working on deciding the oil feed line right now so any suggestions would be great. The oil return line is pretty much self explanatory. Also, trying to decide on an ecu. Stand alone, if so which would you guys suggest, or an em ecu through hondata which I could program/re-flash. I would like full control but this is also my daily driver haha but any tips or pointers to get me going in the right direction would be great. Also, current mods is ported and polished intake manifold and three inch straight exhaust from cat back and stage one clutch.
