2JZ GE (USA is300) with Waste Spark and Link ECU
Introducción al ajuste del motor
1430 Vistas
Greetings all enthusiast. Quick question:
With an is300 2JZ GE with waste spark setup, can I wire the coils separately, like a 2JZ, and not run waste spark from the Link?
All the best,
Kieran
Hello, Kieran yes you certainly there are six ignition drives in the ECU. check the link help file in pc link and click on wiring information then plug under the contents find the Plugin installation manual for the pinouts
Regards Ross
Thank you Ross!
