Dodge throttle position on Hp tuners WOT
Introducción al ajuste del motor
Módulo relevante: Ejemplos resueltos > HP Tuners Dodge - Tuning ANN Hemi de 5.7L > Paso 6: Confirmar la calibración en la carretera
262 Vistas
This may be a dumb question, but I noticed when you guys did the ramp run the accelerator pedal position was 91% and the throttle position and other means of measure were less (like in the high 80% range). I noticed on my car it is 85% with WOT. Is this a function of torque being more than expected and so it is cutting throttle body position? Is it normal to not be 100%? Just curious. Thanks in advance.
