Earthing the gearbox to the body
Introducción al ajuste del motor
1868 Vistas
Hello, you stress the importance of having only one connection between the engine block and the body. But I also heard it was important to also connect the gearbox to the body as well. What’s you insight on this ? Thank you
This would seem to be a good idea, but there is a phenomena called "ground loops", where the actual relative voltages of a 'ground', or 'earth', can vary depending on the location and the amperage of currents through the earth - remember, in order to get a current to flow it has to be pulled/pushed by a voltage difference, even in something that one might assume to be the same throughout.
This is why it is important to use a single point for an earth for most electronic circuits, as they will typically operate in differences of milli' or even micro' volts or amps - that's thousandths or millionths, so you can see how even a litlle difference is important!
When you introduce a second engine/chassis earth point you can not only affect the ground potentials across the engine-transmission, which can affect their electronics, but also between the chassis points that they're grounded through.
