my first post here, I'm hoping some of you guys might be able to point me in the right direction for a shallow or winged sump for an f20c from an s2k
I'm currently in the process if sourcing parts to put the f20 in my fisher fury over the winter (UK) and ground clearance is going to be a key issue with the f20 over the fiat TC i have in there now.
ive seen the dry sump kits, but this will blow my budget wide open. and also give me packaging issues as, the car is tiny. with not many tall spaces to locate the tank.
the Fury is currently 590kg, so the f20 should liven it up , I'm hoping the f20 is lighter than the fiat TC as it a steel block but its such a simple engine i think they will actually come out pretty similar.
thanks Andy
