Nitrous for ALS at 2500-3500 rpm on an LS3 turbo drift car
Introducción al ajuste del motor
1579 Vistas
Hello
I have been trying to figure out if using a 50 or 75 hp nitrous Jet at 2500-3500 to assist with spoolup in certain cituations on a Drift car
Just wondering if injecting nitrous at such a low rpm would be a bad idea , As soon as boost would come on we would disengaged nitrous
regards
Gudmundur
A little bit more information would be helpfu , it's it a built engine?
What torque are you running and what torque is your engine built to take?
Adding nitrous that early is going to generate a fair amount extra torque, how often are you really that low in the rev range when Drifting?
