Corner Balance course
Ponderación práctica de esquinas
Discusión y preguntas relacionadas con el curso Rincón Práctico Ponderación
2069 Vistas
Nice job on this course. I’d like to suggest a way to better improve this course if you guys are listening? I believe the final module could be improved by using a car that is not perfectly sorted from the get go, and needs changes after doing some laps. When you might address tire pressures before pursuing a suspension change and under what conditions. Perhaps an oversteer or understeer issue on the track or a braking issue, and in what logical order you might approach it. Logical steps in combating various problems that occur at the track. One could further improve their knowledge by offering that.
Warmest Regards,
Joseph Rodriguez
Hi Joseph,
We're always open to feedback! Thanks for giving us your suggestion on this. This is something we will take into account when adding future worked examples!
Thanks,
Tim
