Front vs Rear and Left vs Right corners from course...
Ponderación práctica de esquinas
Discusión y preguntas relacionadas con el curso Rincón Práctico Ponderación
2521 Vistas
Couple questions about course and setting that gt86,
- why front to rear was left with this much diff. and not try to get it closer to 50/50 with ride height , it is set at 57,64% vs 42,35% - if I'm not mistaken,
- same goes for left to right corners,
- you could still get diagonal to 50% and fix those parameters with height of each corners.
I have Honda S2000 on scales and need to prep. it for circuit racing (track days car) well balanced car on it's own , added driver weight is problem.
