GT86 rake
Ponderación práctica de esquinas
Discusión y preguntas relacionadas con el curso Rincón Práctico Ponderación
2003 Vistas
In case of your GT86, di you applied a positive or negative rake?
Hi Massimo,
Sorry for the slow reply to this! In almost all cases, you want a rake with the nose down. You want to keep some rake in all parts of the track. The convention for what is positive and negative will depend on who you are talking to, normally I'd describe this as a positive rake.
Cheers!
Tim
