033 | Setting Up a Driver Rotary Switch on the Motec M1
Preguntas del seminario web
4323 Vistas
Motec’s M1 range of ECUs give the tuner a lot of flexibility to control various features by using either a two position switch or a multi position rotary switch. In this webinar we will look at how to input these switches into the Motec M1 ECU and how they can be used within the software to control various functions such as launch control, traction control and boost control simultaneously. For this webinar we will be using the Motec M150 fitted to our Toyota 86.
Watch: Setting Up a Driver Rotary Switch on the Motec M1
English Captions: Available.
As always, if you have any questions about the webinar please ask below.
