103 Plex knock monitor - double knock sensor?
Preguntas del seminario web
1491 Vistas
question: it looks as if you had the plex knock monitor and the knock detection of the ecu running parallel on the same engine at same time?
If so - how did you do that? Puttink knock sensors on top of each other?
We have done so on engine dyno once but it did require special knock sensors...
but maybe I got wrong impression by the webinar
