220 | How to Construct Ignition Leads
Preguntas del seminario web
1597 Vistas
Just a continuation from the latest webinar:
kelvinp45: Are there styles of ignition lead that ground any EMI at the ends of the leads?
Andre.Simon: Hi Kelvin, the problem is thaT THE LEADS GENERATE emi RATHER THAN COLLECTING IT. i THINK YOU'RE REFERRING TO A SHIELDED CABLE THAT WE MAY USE ON A SENSOR WHICH COLLECTS THE emi AND DRAINS IT TO GROUND.
Andre.Simon: sorry for shouting...
Taz.Quinn-Walshe: *loud noises*
kelvinp45: Haha sorry I asked! I'll come back when you're in a better mood!
Isn't that essentially the same thing in reverse though? So you drain away EMI before it reaches anything that might pick up that EMI? Like the radio for example.
