241 Tuning for elevation change
Preguntas del seminario web
1880 Vistas
Greetings to all,
I have a doubt, I have seen in some cases, that the tuner uses only the barometric sensor without mounting a MAP sensor to develop his maps with a Marelli SRA-E ECU. Is this methodology correct?
Thank you very much!
I tuned a normally aspirated Judd V8, that was setup for sea level, Alpha-N mapping (no MAP sensor) to run at 5000 ft (1500m) It had a Barometric pressure sensor, but there was no compensation. I added the normal (half the air, half the fuel) linear compensation, and the tuning was spot on.
So I would say using the Baro sensor without a MAP sensor is totally workable for a normally aspirated engine. I can't see how you could have forced induction engine without a MAP sensor.
Thanks for your quick reply David. I forgot to specify that I have only seen this in normally aspirated engines.
Grateful to learn from all of you!
