96 Honda Civic Wiper Motor control for MoTeC PDM
Preguntas del seminario web
1722 Vistas
I’m configuring my new MoTeC M150, C125, PDM30, and 15 button keypad. The PDM courses have been great help, I’ve watched the webinar from Andre about PDM set up for wiper control. I have a 96 EK Honda Civic and trying to figure out how to wire the wiper motor. In the webinar Andre mentioned he had to rewire the older wiper motor from the FJ40 as it was negative switched which I think my Honda one is too.I’ve attached a schematic of the wiring, is anyone able to help determine which wires I would connect to neg, which to the parked input, and which to high & low please?
I’m thinking
Pin 1 high speed - output 10
Pin 2 low speed - output 9 with linked control
Pin 3 not used
Pin 4 Negative - swap to chassis
Pin 5 park input - input with a pull up
That looks very similar to who my Subaru is wired. You don't need the pull up on it, as the digital outputs have an internal 10k pull-up to battery+ on them, that is pulled to ground by the switch circuit.
