Episode 2 [OFF THE RECORD] - connecting Innovate to OE ECU
Preguntas del seminario web
1888 Vistas
Hi Andre, in this episode you say that you've connected an Innovate wideband to the OE ECU to log in RomRaider. Please can you expand on you did that as unlike aftermarket ECUs the OE one doesn't have any configurable aux inputs? Many thanks,
In this instance the wideband isn't actually wired into the ECU. It is brought directly into the laptop via a USB to serial adaptor. You can then select within Romraider which COM port you've connected to. This simplifies the connection, doesn't require modifications to the factory wiring, and gives you reliable AFR data.
Awesome, will give it a go.
