Mapping Oem sti ecu
Preguntas del seminario web
2532 Vistas
Can anyone teach or help me how to map, active als and launch control on Subaru wrx sti Oem ecu using rom raider or any other software that can map Oem ecu's via the obd ports?
Shall highly appreciate an urgent answer and if one can corresponde via my email add info@uniworkz.com
If you're using open source then you can use the patches from this site:
http://www.ecu-mods.com/online/
I've used them on a fair few cars over the years and have never had an issue with them
Chris250
Thank you for your help, please can I have you email address as well and are you a commercial mapper in the UK?
I am yes, if you have any questions just ask them on the forum, we're here to help
