Plex Knock Monitor
Preguntas del seminario web
1646 Vistas
Hi Guys. By listen to the Audiodetection there are Clicks close to the Rev Limiter but in the Graph no Points higher than the thresehold. It beginns around 500 Rpm before the set Rev Limit.
Thanks
Have you tried changing to different filters? Some are not suitable for certain engines and result in what may sound like knock. It's important to find the best audio filter for your particular engine.
