Webinar - 121 - Can Bus wideband to suit Analog pin input?
Preguntas del seminario web
1795 Vistas
As title states, is this even possible? if so, has anyone successfully done this?
My PCM only has 0-5v input for wideband unfortunately and I cant go changing to another brand for a Can BUS input.
Many of the wideband models that deliver data over CAN also provide an analog voltage output (AEM X-series WB controller, Motec PLM). Buying one like that might allow you to move the CAN-based support if you change ECUs in the future.
Cheers David, so there would be no way to make a CAN wideband work with an analogue ECU input to achieve better accuracy for wideband readings?
No cost effective way. All solutions I can think of cost more than a different $200 wideband controller.
