Webinar 186
Preguntas del seminario web
1464 Vistas
Hello Andre how are you ,2 question here the first one,to use on a normal gear box to as clutch switch as a rpm limit will that have affect if you use launch control base on wheel speed disarming speed.like the clutch switch will be active be4 the launch control rpm.
on the Link g4+ what is a good start point to use or to fill in the GEAR SHIFT CONTROL menu when using a dog gearbox with a shift knop with 2x build in micro switches lets say on the gear shift control menu from end of gears lock out all the way down . .
