Webinar 196, Rotary Switch Setup Spreadsheet
Preguntas del seminario web
1858 Vistas
As promised in the webinar :-).
https://docs.google.com/spreadsheets/d/1S1C__TfY51vhCPVa19NsGoGa-t4up9wHHsqLvROjz-w/edit?usp=sharing
Its a quickie, so you'll be able to break it, but hopefully it helps with setting up those rotary pots! The shared link is 'view only', so you'll need to save a local copy to edit. Throw up a pic of what you're putting them into :-).
