webinar non VE based ecu
Preguntas del seminario web
1900 Vistas
Are you going to do a webinar with an ecu that does not use VE but still a very popular ecu, like a Syvecs. Seems the most used ecu for more sophisticated setups where DSG type gearboxes needs to be controlled and other hardware in the car that uses CAN. Would like to see a webinar on this type of ecu.
We are a little limited right now on what ECUs we can easily demonstrate on our test vehicles. in the very near future we will have our engine dyno up and running. This will allow us more flexibility to swap between a wider range of ECUs. Syvecs / Life Racing are on our list.
Understand however that despite the differences between ECUs, the principles that we are applying during the tuning process don't change.
