Webinar suggestion on water methanol injection
Preguntas del seminario web
2007 Vistas
Andre/Ben,
Have you guys ever thought about running a webinar on tuning an engine that is using water methanol injection?
I'd love to hear Andre's thoughts and strategies on implementing this.
Chris.
It's not something that's very popular or common here in NZ but I don't doubt its effectiveness. I've always been a little apprehensive due to the problems that arise from running out of water. Modern systems with fail safes however fix a lot of this trouble and it's definitely something we can consider a webinar on.
I'll put it on the list :)
Thanks a lot for the consideration Andre.
It is something that is used quite a bit here in trinidad because of our ambient temps and also our pretty shitty fuel.
I actually want to implement it on my high compression NA suzuki ignis engine, something that is not very popular since its mainly used on turbo applications hence why I'd love a webinar on it.
Chris.
I'll see what we can do.
