Hello
Evo 8 , kelford 292 camshaft ( solid lifters ) stock rocker arms ( drag racing car )
What is the main cause for a rocker arm failure for this engine .
Keep breaking rocker arms ( on start it brakes one , on reving too , last one lost a valve and lost the engine )
I need your advice , go back to the stock hydraulic lifters ? Or do I need aftermarket solid lifters .
I have this to the head too Kiggly Racing HLA Oil Pressure Regulator Mitsubishi 4G63 Evolution
I know we have something wrong plz point me
Thank you in advance
How about cold clearances for solid lifters- that are they? What solid lifters do you use?
Hello
0.20 cold clearance .
Solid lifters I have no idea about the brand ( bought it with the old engine ) but does it make a difference and what brand you suggest I can buy if this solve my problem .
Also what rocker arm you suggest , running stock now .
Thank you
I have bought Tomei solid lifters for stock rockers - those have proven their quality over time. Cold clearances seem to be a little too much - 0.12 intake and 0.14 exhaust should be fine. I'm sure your problem is with lifters clearances - there is no other way to brake the stock rockers as they are very strong and capable of holding 1000+ hp.
I'll buy this tomi solid lifters and get the clearance to /.12 & .14
I put it 0.20 as the cam card specs .
Do you think I need this ? Kiggly Racing HLA Oil Pressure Regulator Mitsubishi 4G63 ,
Keep it or remove it ?
Thank you
I use Kiggly as well- no problems.
Thank you so much
Hello
I found that we are using the BLE solid lifters .
Plz can you send me the part number for this tomi solid lifters you use .
Also how often you check you valve lash . This is a drag racing car .
Thank you
Hi. It is 163039. But you might need some of shims to get you to the correct clearances which are checked before every racing event.
I am buying it with the shims set .
Do you recommend tomei spring valves too ? And which one works with my cam shaft kelford 292 solid lifters .
Thank you
Any springs that would overcome the boost pressure acting on the valve total area should be just fine. For instance my peak boost pressure is 3.2 Bar so i use GSC springs for 3 Bar boost.
Might be a bit of a wild card, but have you checked the clearance between the spring coils on full lift, some aftermarket springs (don't know about those specific ones) will specify re-machining the spring seat and/or use of specific spring retainers - if there is a coil bind problem (harmonics may actually close them up) then the forces could easily break a rocker.
If one failed, let alone several, I would suggest careful inspection and crack testing of the other rockers. You may even find some other evidence leading to the failures.
Yes, indeed- it is something i had taken as granted, the springs have to be checked in terms of intalled height. And rockers also need to be revised. I personally replace them for new stock OEM ones every time I reassamble the engine which is once in 4-5 thousand miles.
Hello
Too much information to be taken into consideration . So today I'll recheck the spring valves and let you know
Thank you so much
Hello
Thank you so much
